2G How to re wire AC compressor
GsxAwd2300
5+ Year Contributor
62
Nov 7, 2017
Prov, Rhode Island
So when I rebuilt my motor I did some looking around and could not find the ac compressor wire connector , no I regret not looking until I found at least where they prolly cut the harness
Anyways with cylinder head back on I can’t see much and I cannot find the wires to the ac compressor
Moving forward I’m going to neeed to re wire it and I have no idea how ?
There supposed to be three wires that goto the ac compressor
Have you looked at the electrical diagram for the compressor? You could work in reverse by finding the next connection point, like the ecu or AC control unit and work your way back towards the compressor.
Well that’s why I’m thinking is the next logical step I don’t have a that diagram though
I see said the blind man
It’s branches off the cam angle sensor which is supposed to be sprocket side
But I have a 6 bolt swap and my cas is evo side also likely they deleted aC at the same time. I’m likley to find my ac wires in that birds nest !
Best of luck locating it!
