how to prpoperly dyno an auto?
n2orbit
298
May 10, 2003
How do you do it? what gear and such.. i'm wondering if my tranny is on it last leg every run i try my tranny slips bad.. i was doing it in 2nd gear. it holds at 20mph then when i floor it engine speed goes up ust a tad but i can take the revs to redline
Well, since your supposded to do dynos in 3rd. I would think to put it in drive with od off. Wait for it to shift into 3rd then start the dyno from there.
theres a setting on the computer for automatics on the dyno. it uses a different calculation. you basically leave the od off and just put it into drive then do a full pull from about 30mph all the way to redline after all the shifts.
When I dyno an auto I do it in 2nd gear and punch it at around 35 mph. The gearing is different than a 5speed. It takes too long and creates too much heat in 3rd.
