How to perform boost and leakdown test
AWD 90 Tsi
48
Sep 5, 2006
Oklahoma city, Oklahoma
I tried to search (how to perform leakdown test) and (leakdown test) etc, but no help, my question is does anyone have a link or can explain how to do a leakdown test (the one to see if air is bypassing the valves or rings) and what tool and where to hook it up for a boost leak test?? Thanks
You need to learn how to search more effectively. If you search using "leakdown test" with the quotes, you'd have found dozens of links, and I found a few in a couple of minutes that have this link in them.
As far as the boost leak tester, go look at the Stage 0 mods page or the intake tech article library.
try here for the help that you are looking for. Also when you search try just searching for topics only, the results for everything can be overwhelming. Hope this helps.
AWD 90 Tsi said:
oh i didnt know about the quotes thanks
No problem. If you leave out the quotes, it finds all articles with either "leakdown" or "test", and the "test" word will show up everywhere resulting in a hopelessly long list of hits. If you get clever with your searches, you can find just about anything.
