How to install a wet kit etc...
fwdtsi
197
Feb 16, 2003
I just recieved my wet nitrous kit, I am wondering where does the fuel line need to be put. Also if my injectors are already at 100% duty cycle would it be safe to run a 30 shot? BTW they are 550's
I haven't installed one in my dsm yet but I plan on t-ing off on the fuel feed line. Cut and splice. A 30 shot should be completely fine as nitrous runs off the fuel pump and has nothing to do with the injectors.
So you are going to tee it off the fuel line? Doesnt B&M make a special tap off your fuel filter? and if you do tee it cant the fuel pressure blow the line off the tee? becuase thats high pressure. If you do install it can you tell me how you got the tee clamped down?
I planned on cutting the rubber fuel hose coming off the fuel pressure regulator and teeing that line. I plan on using hose clamps to tighten the hose on. I may be getting the kit this week but I would not have my car running for another week or so. Turbo swap is still awaiting fitment parts. I have heard of people tapping the fuel filter but I don't know how. I am not sure about the BM regulator though. I have a buschur setup and no place to tap it.
Originally posted by fwdtsi
Does anybody have a wet nitrous kit installed right now? Can you tell me if you tee'd it off the fuel line? Have you had any problems?thanks
Yes but mine instaled on a 2gnt. I taped the test port on the fuel rail it was really easy
i dont think a T after the fpr would be good. i'd do it before the fuel rail and after the fuel filter. thats where fuel pressure is regulated.
It is $4.XX around here... so a 10lb. bottle is forty some dollars. I had it on my old integra.
