How to get the CEL back?
Outdorsman
338
Oct 17, 2012
Las Vegas, Nevada
Well stupidity led to disconnecting the battery when I got a CEL, I assumed it would be there again when I reconnected it but no.
Is there any way to get the CEL to come on again? I can't really find out whats wrong with my car until I get that CEL back.
By disconnecting the battery you reset the ECU, so for now there is no CEL. Drive the car around till it throws the code again.
No. There is no other way. If the conditions of the CEL are met at idle then yes it will flag it. If not then no, the only other way is to drive it. Unless you have some suspect of what CEl this is there is no way to know. . We don't have enough information. If you had no symptoms, just a CEL you'll never know what it was. You'll only know if you get another CEL well...you've got another CEL.
I have reason to believe my car is out of timing. It hesitates, shakes, studders and won't move. It tends to die unless gas is applied. It had a CEL when all this occurred but its gone now. Thats why I want it
