ucancallmedebo
- 82
- 0
- Dec 3, 2004
Winston-Salem,
North Carolina
I have a sidwinder 5000 alarm and I have looked for some time and cant find out how to disarm the auto lock with ignition on . The valet switch and led are working properly and the car is stuck in auto arm and lock 30 sec after ignition is turned off. This is ok cause I got a turbo timer and can just leave the car and it will shut off and arm itself but I always have to unlock the door when I get out and leave the car running by hand.. Does anyone know how to turn this feature on off. Also how to turn the auto arm on off. All I have been able to find out is how to put it in valet mode, but then the alarm only locks and unlocks the doors and still locks the door with the ignition on. Any help would be greatly appreciated. Thanks.
. Does this sound alarm related? Does the eclipse 1g type power door locks work on a grounding system and the unlock is grounded out somewhere? It acts like my old bmw when you try to lock the doors with the door open. The door adjar light is out and works for both door and regardless they should still lock even with the door open. This car has a nest of wires under the dash and when I bought the car I went thought them and resodered bad wiring and electrical taped connections. I remember a couple months ago the car did this and it just went away after some days on its own? Any thoughts?
