Alarm install questions.Where to find door lock wires/
Gamble97
2,642
63
Jan 3, 2006
small town, Illinois
I'm installing an alarm on my 2g and I can't find the door lock wires. I know what color they are, but I'm looking under the dash and can't find them. What's the easiest way to locate or tap into them? Should I do it from behind the fuse box? Or is there a harness that gets unplugged so that I can get at these wires? Are they connected to the ecu so that I can get at them?
Any help would be great, pics would be even better.
Thanks
Hey i just installed a keyless entry in my GS and i tapped into the door lock/unlock wires right at the relays.....they were behind the radio in my car i would think theyre the same in yours. You can also find a few of the wires you need in the stock keyless entry harness which is located behind the rear drivers side panel near the speaker.
ah good idea. I'll look into it. I am not sure if this car had keyless entry though, because when I bought it I only got 1 key.
How did you know which relay it was?
Behind the radio there was 2 relays ....for me it was the one on the right but to be sure put your finger on the relay and lock/unlock the doors if you can feel the "click" then thats your relay. Also i used these and it made the install go alot smoother http://www.radioshack.com/product/i...&cp=&sr=1&origkw=tap&kw=tap&parentPage=search ... ive had the keyless entry in for about 2 weeks now and none of them have ratteled loose or anything.
Pics would be awesome, if anyone has any.
I can't find them at the kick panel for some reason.
