93 alarm install- where r Lock,parking lights,door switch?
jjsacidy
224
Jul 14, 2004
Saint Cloud, Minnesota
i got my crappy ebay paging alarm and have it partly installed. now parking lights are green/white correct? is it the green/white wire in the harness right above the fuses and the stsp relay i believe? on the end of the plug? and i have no idea where the lock wires are, well besides in the door. where are they in the kickpanel? i dont see any brown/blue? also what should i use for a door switch? i can use pos. or neg. i dont have to route a wire to the pin switch do i? if so which wire on the switch? somebody please post pics! i can also see my side neon bulbs. most people think its looks good tho LOL so i dont know. stupid built in trans doesnt allow it to hide behind that ridge... thanks
also- i hooked the ignition wire up to the stereo accessory, any problems with that? this isnt remote start or anything and it seems to work just fine. if the ignition wire gets 12v during cranking cycle y does my heater blower stop then?
"Parking Lamp Green/White (+) at relay "-vfaq "just to make sure, you do know that it's a negative control system right? That means when you turn your parking lights on, it sends negative (-) voltage to the light circuit. If you need it as a power sorce, be sure to use a relay and not just the wire directly. If you need to use that wire to turn your lights on, such as for an alarm, etc.. then be sure to use diodes to block voltage going where it shouldn't.
it's the green w/ white stripe wire in the gray connector at the base of the turn signal lever."-another post
--- so... can i just hook my 7amp positive lead to that wire? or do i need another relay to make it negative?
"The lock control is in the passenger side kick panel. But, the wires you are looking for are just to the left of the steering column up through the bottom. There is a black plastic strip holding 3 relays? with two screws. Pull that down, and you are looking for the blue/brown wire and the white/brown wire. Ground those two to figure out which one locks and which unlocks, then tap in your wires." -another post
---- ok now i understand that and should be good on the lock triggers.
"Door Trigger Green/Red Above Hood Release Gray Connector "= hmmm i think i saw it
