2G how to check for fuel pressure
That tester would work fine, but using it on the return line will just give you a zero reading. There is no pressure on return side after regulator, you want to test fuel at the fuel-rail inlet side. I have a tester similar to the one you mentioned, I just cut my rubber hose after the filter and inserted the tee fitting to check the pressure. When I was done I used a brass push-lock fitting and 2 hose clamps.
I reccomend using the gauge and fitting b/c its cleaner and whenever engine is running you just pop your hood and look at it.:thumb:
