2G How to adjust Greddy Type RS BOV ?
Pezking
101
May 18, 2004
Ludwigshafen/Ma, Europe
Right up front, this is not on the technical way of adjusting it, I know how to adjust it, but I was wondering to what strength I should adjust it...Should it open at the smallest amount of boost ? or only at higher levels ? ( When I get off the gas of course...;) ) With the stuff I'm running, I see 13-14 psi when I floor it.
Any advice on the adjustment ?
It should blow off cleanly at 1 or 2 psi. That's how you know you've got it set correctly.
Bov has nothing to do with the amount of boost your running. You can tighten down the bov if its leaking, but at that boost level its doubtfull. Should have a nice sound to it if its adjusted right.
according to the manual that came with the greddy type rs. loosen the set screw until you hear air leak at idle, then tighten back one full turn. i'm sure thats a universal application though. i have a type rs on my gs-t and i think i tightened mine about 1 full turn from where it was from the factory setting.
