dsm-onster
DSM Wiseman
- 8,592
- 132
- Jul 11, 2004
Bloxom,
Virginia
I'm going to paste in everything that member Vigge PMed me yesterday. His real world testing says exactly what I would speculate through theory. So there's no need to insert mathematical aphorisms.
Vigge in his PM to me said:Noted there is a pipe size related topic on the forum and here is some measurements which relate to that issue.
The reason for doing these measurments where to point out to a "bigger" audience in the saabscene that majority who invest in larger pipes are just wasting money and worsening their set-up since there aren that many saabs around in which the bhp level would be so high that the original 2" (45mm I.D.) would become restrictre even though some tuners on their website say the opposoite.
Anyhow here is a old post of mine where I compapred the spool and responce with the original stuff vs. 2.5" shiny stuff. Used that same 2" IC-TB pipe in my last viggen set-up also which produced around 600bhp/650Nm
The aim of the following test was to come to the bottom if a shiny 2.5" delivery pipe among with a redone TB bend will lead to improvements. The normal claims in fawor of the pipe have been
-smoothner power delivery
-better/improved response
-smoother transition from under pressure to boost
-more power
aso.
Today I covered the responce testing with both T5 orig delivery and aftermarket and here are the the discoveries. Prior to all test the car was driven on highway to "normalize" the conditions. In all logs solid lines = after market stuff, dashed T5 OEM stuff
Response test 3000rpms 4th gear
www.stcf.net/viggen/pipe3000.pdf
TB plate opens slitly later with OEM stuff, but regarless of this the OEM pipe outperforms the aftermarket stuff. Speed difference in the beginning 0.6km/h and 4.3 km/h once at full boost. Difference mainly from lower rpm spool with OEM pipe
Responce test 3500rpms 4th
www.stcf.net/viggen/pipe3500.pdf
more or less the same as above but devieance not as big
Responce test 4000rpms 3rd
www.stcf.net/viggen/pipe4000.pdf
again more or less the same but roughly equal
The above tests where repeated several times to rule out the normal run to run variation, but regarless of it the results are as posted above.
Conclusion, the pipe for sure will do nothing in terms of improved response and I perosnally would vote for the opposite. Smoohter power delivery can be written as slitly delayed power delivery.
For me now it is trying to do the math, but this is what I wanted!
