how much power will i add?
RS-RGS-T
116
3
Mar 1, 2005
To live and die in L.A, California
im boosting a daily 18psi on stock bored out t25 will i gain more power if i ad a bigger turbo and boost the same will it add power and if so how no matter what its still 18psi how does that work and what kind of turbo should i get my motor steal feels strong but i dont wanna exceed 21 psi because it has 117k on it. whats the best turbo for that if i dont wanna boost more than 21psi and at a good price 2?
any turbo will produce more power at that boost level then the t25. What are your goals (1/4 time, whp)? Choose a turbo that will help you get there after you have decided those basic things.
Go to a 50 trim with some 660 injectors.
And yes you will make more power with a larger turbo at the same psi......it's called increased air flow. A t25 will only flow 23 lbs of air give or take a pound. A 50 trim will flow much more at 18 psi.
Yes, more air flow.
I would suggest a an EVO3 16G or 50 trim. With all these vendors out there they are fairly priced nowadays.
Hope this helps a bit. Stay boostin
