how much hp will i get with an mafs
What is a MAS?
What is a MAF?
MAS stands for mass airflow sensor. It is also sometimes called MAF, for mass air flow sensor. It is the assembly that measures the properties of the air entering the engine, consisting of three separate sensors.
From http://members.shaw.ca/costall/1000Q/
Your car wouldn't be running if you didn't have a maf, so you wouldn't be gaining any horsepower by replacing it.
For one try searching and find out the correct part you are asking about. Secondly since you are new here, I will tell you that ANY question involving how much hp you wil get if..... will get either "go to the dyno" or sent to the dead end forum. I'm not trying to be ignorant, just trying to give you a heads up.
Hmm, ignorance is the answer. This site won't take kindly to that.
But to try and answer this.
If you got a MAF-T, and were able to tune it, where as before you couldn't then I could see 5-10hp.
Only if you had no tuning capability before and are able to tune with the translator.
Let me get this right, you ask a question and when asked to clarify you respond with "how should i know. im only 16 y o". I checked your profile, and for someone who owns 5 other cars, and has the mods done that you say you have, I would think you should know what you are asking. Is your profile just a bunch of BS?
