How much did you spend on your bottom end?
shredwin
1,131
5
Jul 6, 2008
Tampa, Florida
This is for the guys that have rebuilt their whole bottom end. Could be either 4G63 or 420A. How much money did you spend on parts? Include What you spend at the machine shop too?
Wiseco 8.8 stroker pistons, Eagle H-Beam rods, and a 100mm crank $1000 (used with low miles)
Machine work: polish crank, resize the rods, deck the block, new freeze plugs, clearance the block, bore over .40, hot tank it, and assemble $500 (friends are awesome)
New piston rings $200
Clevit 77 bearings $110
ARP head studs and Main studs $200
BS eliminator kit $25 (installed)
Oem water pump $100
New oil pump gears and cover around $300
Total $2335
I think for what I have got in there it's a good deal.
Edit: I forgot to add some things like the ATI harmonic balabcer $500
And a new oil pan $100
If I had a lot of money I woud be building a nice bottom end like some of you guys on here... but for now Im going stock everything without balance shafts, I do plan on gettin my OEM crank rebalaced and polshed. $5,000 is still the highest price I heard so far for a built bottom end with machine work included.
