How Much Boost for track?
96TSIAWD17
May 13, 2005
Sioux Falls, South Dakota
what should i run for boost at the track with a fully rebuilt motor 16 or something like 20 ??
Let's assume your profile is updated.
1. You're limited to about 12psi due to the stock BOV.
2. After you upgrade the BOV, you are limited to 15-16psi due to T25 and stock fuel pump/injectors.
3. After you upgrade the turbo and fuel system, assuming you did it right which should include at least safc and logger, the logger will then tell you what psi is safe to run at the track.
In conclusion, 12 psi is what you should be running with the car as is on or off the track.
