how much boost can stock bov and head handle?
futurevokiller
44
Dec 26, 2008
Selah, Washington
i am planning to up my boost i was wondering if my stock bov could handle 20psi? actually, will my stock motor be safe on 20psi? i have a 2g maf, 560cc evo injectors, an intake pipe, a walbro 190, a 16g, and im getting my ecu chipped for my setup. whats the most boost i can run and still be safe? i will eventually get a better headgasket and some arp headstuds but till then i dont want to break anything, but i still want to go faaaast:rocks:
The stock bov may start leaking pressure to the atmosphere and you will loose power and the head can take up to 500 hp depending if you don't abuse it with over revving. There are a lot of factor that come in to play when dealing with the head, but I'd say you'll have no problems boost 20 psi on a stock turbo.
It is different for some... I would say 1G BOV will start leak at around 24-25PSI. Otherwise, you can buy from DEJON TOOL, that 1G BOV leak fix kit and call it a day.
The problrm with BOV is that is actually, physically too small/34mm/ and when you start making good power-500+, it will not release the air out fast enought, just because of its size.
About the stock head, you should be fine..
As I said, every person and car is different... What works for me, might not work for you.
Do not take for granted what people say.. Just go from less boost UP, log the car and analize and you should be fine, GL...
