How much boost can i run
Status
Not open for further replies.
97GsXfreak
137
Nov 15, 2004
Berkeley Heights, New Jersey
Alright I just bought a 20g td05h because i got a good deal on it. However i have almost all the supporting mods except for fuel injectors which i am still waiting on. My question is with a ...Greddy front mount, 255 pump, afpr, clutch, 3inch exhaust and dp, safc, logger, and sum other stuff would i be able to install the turbo with out the injectors?? Maybe like 12psi or something??? The reason i want to install it right now is i am finishing porting my o2 and exhaust manifold and i would like to not have to put the t25 back on just to take it off in a week or so. Any ideas are appreciated. Thanks
if i had 5$ for every single question that came up like this I'd be putting bill gates out of business. I seriously dont see how the moderators and wiseman around here put up with this. Use the search, get a logger!
i will agree that if you just use the seach there are a million questions like this, but i'll answer it anyway. i think you'd be fine just letting the wastegate open whenever it does normally, i.e. don't use any form of boost control or have your MBC all the way open. around 10-12 is usually fine for most setups, but then again i'm not very well versed in the bigger turbos. hope that helped - mainly just use good judgement.
Status
