How low can you drop a talon before needing cambers?
My rear bushings went out right away after installing springs n my car without the camber kit. :(
I know for a fact if your ride height is under 100mm you WILL need camber correction for the rear wheels. You can get away with a little negative on the front, it won't hurt anything. I run -2 degrees on the front.
I'm sure if you looked around you could find more detailed information, this is just off the top of my (rather frazzled) head.
Yah man, VFAQ homemade camber kit has worked great on my car and for the price you can't beet it.
what kinda drop did you get and can you link me to them or are one of my ebay links them? or do you mean it's in the Faq?
iowaboostin said:
"You get what you pay for" is shown to its fullest when it comes to suspension.
I agree wholeheartedly, but you can do the home depot rear camber fix. It works just fine :thumb:
99gst_racer said:
My car only has a 1.5" drop and my camber was horrible before I got a camber kit put on. If you're going to lower it 2", then you will definatily need a correction kit.
I realize that want to help point me in the right direction
If you trust your own skills, I'd make a kit as per vfaq.com.
If you just want to purchase one, I'd get an Ingalls kit. They seem to be the best. I'll let you do a little searching to find out where to get one.... :thumb:
