How long can a car sit without or with but without starting
cmptrphreak
194
Jan 7, 2005
Chicago, Illinois
I just changed my oil pan gasket but found bad water lines for turbo. I was wondering how long can my car sit without oil or with oil but without being start, IF I manually crank the motor once in a while is that enough? I have no money now cuz I have to save up for lawyers. thanx
Cars can sit for an extremely long period of time without any damage being done. Oil will still be coating the internals of your motor while it's sitting, protecting it from corrosion. Just make sure your engine bay stays covered and protected from the elements to keep any electronics from malfunctioning. Keep it in a garage too if possible to keep critters from crawling up and doing damage by chewing through exposed wires(had it happen to me before).
if its going to sit there for a very long time, dont you have to worry about tires... and the batterie will probably run down.
Disconnect the negative battery terminal (or just remove the battery), and drop a tbsp. of oil into each cyl. It will be fine. Cars can sit for a LOOOOONG time w/out starting. Mine has sat for almost a year. :barf:
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
