Starting engine without axles?
squid267
158
3
Jan 14, 2012
Dallas, Texas
Almost completed on my 6 bolt swap. Dropping the block and tranny in tonight. I was wondering if I could start it up without the axles connected as long as transmission is in neutral.
My driver side axle broke and the replacement doesnt come in til later this week but I'd like test and troubleshoot this engine sooner than later. Theoretcially it should work.
Thanks
Yes you can start the engine without the axles in place. Only need the axles if you want to give power to the wheels.
You're good to go
When starting the motor without axles or most of the oil in the transmission, even though it's in neutral, the transmission will still rotate! Depending on how much oil you have left in the transaxle, this might not be a great idea if you care for your transmission.
I did it the last time i put my motor together and even build a few psi of boost in neutral before i realized that the tranny was still spinning. No ill effects, but i did prob still have some oil left on the synchro's and it did give me a couple sleepless nights just thinking about it.
If you just recently drained your tranny and think it still has some oil residue, you could prob try to see if you could start the motor but i thought you should be aware of this.
Run to the hardware store and pick up some plastic retainer cups. Usually in the plumbing department. Measure the holes on the trans and pick these up -
Cut to fit if needed, clean plastic burs off and insert. Not that hard to do
In neutral the main shaft in the tranny is still goin to spin your gonna have to keep the clutch pushed in to keep from anything in the tranny turning, but just to start it up to see if it runs you should be fine just just leavin it in neutral for all the longer it goin to be runnin, it's not like your drivin it around Beatin the #### outta it
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
