How do you take the alternator out of the car?
shoccwave
71
Mar 26, 2010
Chicago, Illinois
I need to replace my alternator and I got everything disconnected, mounting bolts, ground, and power cables and the belt...but I can't figure out how to pull the damn thing out. I don't see a way to pull it out the top, and the axle is in the way through the bottom. Has anybody replaced an alternator before?
I had to do that a year ago. seems like I had to remove all the alt brackets, which there are some hidden bolts that u will have to feel around for, and should be able to just pull it out the top. was a little bit fun when I did it
When i changed mine i had to jack the car as high as it would go from the front. Then i would just make my way through the engine and axle. This seemed the easiest way for me
