how do you recalibrate the stock gauges in a 2g?
97dark_angel
209
Jul 9, 2008
new paltz, New York
i just installed a glow kit for my gauges, in order to put it in i had to remove the pins when i put everything back on the gauges were telling me that i was a 4-rpm at idol but i clearly wasn't and it was telling me i was doing 40-some mph, my question is how do you re calibrate the gauge to say normal :confused::confused::confused:
ummmm kind of the same thing happened to me when i did it may i ask what you did to secure the gauge face down if your answer is tape there is your problem thats the mistake i made oooooo clear tape no no no horrible idea anyways if not then take your needels back off and replace them straight like he said ^^^ hope that helps
i dint use tape but i did put it on top of the stock one
what if i pull out the needle and disconnect the battery and then put the needles back it and connect it do you think that would work or dose anyone in ny have a the tool that he ^^^^^ is talking about that can give a brother a hand ??????
Doing what you just stated will not fix your situation....I myself had that same problem when I got my car...Said it was idling at 4k shifting at 8500 rpm's and said I was going like 35 while sitting still....
Even think of just removing the needles turn the car off and reposition them at 0 rpm and mph? B/c when the car is off you know your not moving and the motor is not running....
Then start up the car and see if the mph needle moved...and your rpm needle should be much better if not dead on...
Jim
ok so i think i got it, i had to download a GPS thing on my phone and do it like that, so mental not for the people that want to do this try your hardest not to pull the needles out but if you have to, remove the stops and take a pic were the needles are so you can put them back and be a close as possible, thanks to the people that helped out
soory about the quality but this is last night ill get better ones
in the day
while its on the key is on on
