How do I change my ATF fluid?
Morel
145
Mar 6, 2004
hereford, Pennsylvania
in a A/T 2nd gen non-turbo?
I've searched and I can't find the instructions on the auto..
Thanks!
to do a simple filter/oil change just drain the oil and take the pan off replace the filter and gasket and fill up on fluid, be carefull though depending on what the capacity is of your tranny youll need to start out with say 3-4 quarts then just fill till full (of course when the tranny is at operating temp).
If you wanna do a complete flush then take the return line hose from the tranny cooler and put that in a pan and run the car for a minute or when oil stops coming out, which ever one comes first. Remember even if you just pulled the drain plug and let the oil drain, there is still oil in the torque converter and in the cooler lines.
