how bad is it
95awd26
Oct 20, 2005
edmonton, Kentucky
how bad did i mess things up i had a set of lifters that only had about 200 miles on them they had been soaking oil for about 6 months so i put them in my engine but i didnt drain the oil out of them when i tried to start the car it sound like i had the plug wires on wrong so i get on here and find out that if i didnt drain the oil out of the lifters it could bend the valve so is that why my car wonts tart have i bent my valves
thanks chris
Try to use some punctuation next time, it makes it hard to read a 100 word sentence. It sounds like you may have bent some valves. I wouldn't reccomend turning the engine over anymore. Just take the lifters out, bleed them properly, re-install and do a compression test.
