selmerguy
- 1,810
- 23
- Nov 14, 2004
Killeen,
Texas
I got my car togeather after putting in a new tranny, rebuilt head with stock internals and new valve seals. Also put in some web 546/547 cams. I just cleaned up the block as the walls looked great, removed the balance shafts and thats about it. New timing stuff aswell. The car dosent idle very well and I think that is a bad ISC motor. I know my afr is right around 14.7 at idle. I still get bad white smoke but not all the time. It is kinda funny. If I let the car idle it will blow some white smoke (enough to hide in if I was in IRAQ) then it will stop. I did notice when I ground out that plug to set the BISS screw no white smoke comes out. Any Ideas? My turbo is oil cooled only so it in not that. The head gasket is a comtec and I have ARP headstuds.
