Whammydill
- 78
- 2
- Aug 1, 2005
Mansfield,
Ohio
ok, I found a hose on my engine to be leaking coolant. I need to replace it but I'm not sure what I should ask for. Bear with me as I try to describe it
If you stand facing the engine bay. On the left side of the engine there is a device that has the hose from the radiator running to it. This device has two hoses (i think two) below it running back to the firewall along side the engine. The lower hose has a hole and leaks coolant when the car is warmed up.
Am I making sense? If you can identify what im talking about thanks in advance, and how hard is this item to replace?
