horrible gas miliege!!!! 70 miles on 1 tank!!!!!
JoEgsX90
183
Jun 10, 2006
Yon, New York
Ok guys can look at my mods in my pro, 6-bolt block bored .20 over and a 2g head 5 angle valve job ect... i have 190 rewired fuel pump with STOCK injectors running only about 13 PSI. I believe my front o2 is bad witch im about to replace shortly but could that cause such a horrible gas milege problem? Also i should add all my emitions line have been taking out , and i believe egr has a block off plate. Any ideas here/??
there are lots of factors ...but the one that steals the most MPG is a faulty front O2 sensor.....
haha, yea well first thing i did was cheak underneath the car to see if i had hole!!! LOL I knew my gas mileage was going to be bad withough emition and ect.... but dam!!! LOL yea i think my o2 sensor is bad, im using a palm logger on palm and stein and its reading 0.01 to about 0.05 something like that. ??? what do you guys think?
Yea i have couple cells actally im throwing a egr valve code because i have it blocked off. Im throwing a REAR o2 sensor code, because i took it off to put my Wideband for the meantime. Im also throwing i think it was fuel pressure sensor witch i have disconect also so its throwing that code.
I dont know how you guys suggest testing for a gas leak, gas evoporates very quickly so its unlikely he'd ever see the leak, how would you go about testing for that.
our 98 gst had a ck eng light every couple days and it was code 0170 i think, it was a lazy front 02 sensor.It ran great but milage stank,so i ordered the denso from www.oxygensensors.com (it was like 54 buck shipped!) and the light went away and mileage has increased. not dramaticlly but better considering the mods done im not sure what kind of mileage we should get with it. stock but factory new bottom end,stock head,ported exh manifold,fp T28 turbo w 17lb actuator,ported 02 sensor housing,3" thermal from turbo back,k&n fipk,16-17lbs of boost,dave brode upper ic pipe with 1st gen bov,intake tube return restrictor removed, new fuel pressure reg,still have to install 04 evo fuel pump and rewire kit from Forced Performance Turbochargers and i put a clutchnet yellow pp and their carbon pad disc in with a fidanza alum flywheel.
