Horrible gas leak.
boostinbort
Jan 13, 2014
Lemont, Illinois
I replaced my feed and return line. After fixing them and starting the car there was no leaks. I let it idle for 5 minutes and no leaks. I brought it around the block no leaks when I got back. Let it idle for 2 more. and it started pouring gas. Okay at this point I thought one if the lines broke open, it poured 1-2 gallons in 30 seconds and coming from the rear near gas tank. I started the car 10 minutes later and let it idle for 3 minutes and no leaks. I think It might be the Evap line? I know all emissions were deleted on this car and I wonder if that could be the problem.
Any help is appreciated, thanks
You need to redo that gas line. The emissions delete has nothing to do with it. Sounds like it takes forever to build up pressure from leak then once it gets up it pours out. Check both lines you replaced visually while it is leaking.
