Boost Leak=Horrible Gas Mileage?
RedTalonTsi'91
Oct 5, 2008
Omaha, Nebraska
Hey Guys,
I've got a 91 talon tsi. It doesn't really boost until about 4000 rpm and then doesn't pull hard after 5500 rpm. Pretty sure it is a boost leak. I don't have the equipment to do a boost leak test so I need to get that together. Just wondering if a boost leak would effect my gas mileage. I'm getting about 11-12 mpg. I've only owned the car for a couple of weeks. It is all stock.
Yes, it can have an effect on your mileage. I doubt it would have that much of an effect by itself though. Suspect a bad o2 sensor or coolant temp sensor.
Thanks, I will check those as well. I'm thinking about changing the spark plugs, fuel filter and other general maintenance parts to see if that helps as well.
