1. Join the Community!
Hoods.
Posted by D's GS-T, Jan 19, 2010
Please Support VR Speed Factory
Please Support STM Tuned
  1. D's GS-T
    D's GS-T Proven Member
    228
    Joined Nov 24, 2007
    LaCrosse, Wisconsin
    Are there any good C.F hoods out there that properly vent ait out from under the hood. I figured i could save some weight, and get rid of some heat all at once by picking one up
    445  0
    1995 Eagle Talon TSi AWD
    · 2G DSM
    Loading...
  2. Scott McIntyre
    Scott McIntyre DSM Wiseman
    287
    38
    Joined Mar 15, 2002
    Halifax, NS, Canada
    I'm kinda in the same boat... Searching for a vented CF hood that is functional yet clean looking.
    After looking through many pics, the VIS Racing Extreme GT CF hood seems like it might fit the bill. Here's a couple examples:
    2K  0
    1997 Eagle Talon TSi AWD
    manual · 2G DSM
    Loading...
  3. snowborder714
    snowborder714 Moderator
    12,073
    228
    Joined Oct 15, 2006
    Mechanicsburg, Pennsylvania
    Do you think those small vents would be as effective as an OEM CF hood with a strategically placed Carbontrix vent or two?
    3K  0
    1995 Mitsubishi Eclipse GST
    12.529 @ 110.820 · 2G DSM
    Loading...
  4. eclipse gsx
    eclipse gsx Proven Member
    200
    28
    Joined Apr 25, 2008
    penitas, Texas
    LOL haha but theres other ones ive seen that have a bigger vent in the middle that one is sick and is the perfect one for you
    Street Build 447  2
    1998 Mitsubishi Eclipse Spyder N/T
    fwd · automatic · 2G DSM
    Street Build 1K  11
    awd · automatic · 2G DSM
    631  0
    1998 Mitsubishi Eclipse GSX
    manual · 2G DSM
    Loading...
  5. agarc023
    agarc023 Supporting VIP
    728
    8
    Joined May 14, 2009
    Vista, California
    Like the evo style ones?
  6. Scott McIntyre
    287
    38
    Joined Mar 15, 2002
    Halifax, NS, Canada
    I haven't seen either in person, but judging by photos I suspect the two vents in that VIS hood would equal one carbontrix vent. Perhaps someone with fist-hand experience could chime in. *shrug*
    2K  0
    manual · 2G DSM
    Loading...
  7. snowborder714
    12,073
    228
    Joined Oct 15, 2006
    3K  0
    Loading...
  8. D_Eclipse9916
    D_Eclipse9916 Proven Member
    1,002
    13
    Joined Mar 4, 2004
    Vienna, Virginia
    I worry that although that hood above looks better than a carbontrix, it is not nearly as effective. First of all it does not have a lip to help produce a low pressure zone above the vent increasing the effectiveness of the vent. Second the location, it looks to be above the valve cover, instead of right behind the radiator. Third, again location, the farther the vent is up, the more itll first be away from the airflow that your trying to vent out the radiator, and second itll be closer to turbulent air near the base of the windshield, again, reducing the effectiveness of the vent.
    I had great success with the carbontrix vent and could see the effectiveness when I sprayed the front with a powerwasher, you could see the vent actually PULLING air out and over the hood and over the roof (like a windtunnel effect). It also effectively reduced my coolant temps on track. Also ducting up your front end greatly increases the effect due to higher pressure moving to lower pressure (vent).
  9. gixxerdrew
    gixxerdrew DSM Wiseman
    520
    19
    Joined Oct 5, 2007
    Yokohama, Japan, Asia
    copies of my hood will be for sale for a limited time later this summer, dont know if that helps.
    2K  56
    1997 Mitsubishi Eclipse Spyder GST
    manual · 2G DSM
    Loading...
  10. Choch1
    Choch1 Proven Member
    112
    Joined Oct 1, 2008
    tempe, Arizona
    I have the carbontrix vents, I live in phoenix, 115 summers. These things works wonders!
  11. UofACATS
    UofACATS Proven Member
    650
    14
    Joined May 11, 2004
    Tucson, Arizona
    /\ Very nice. Do you have info on the install?
    so clean, yet so functional :rocks:
    1K  0
    1997 Mitsubishi Eclipse GSX
    · 2G DSM
    Loading...
  12. Strm Trpr
    Strm Trpr Proven Member
    1,584
    76
    Joined Jan 20, 2004
    Lodi, California
    I'm rocking this hood from Seibon.
    It is a very high quality piece.
    The vents are large enough for a cat to climb into your engine bay if the mesh wasn't in place.
    1K  0
    manual · 2G DSM
    Loading...
  13. Nic_Di_Censo
    Nic_Di_Censo Probationary Member
    Joined Feb 10, 2019
    Houston, Texas
    I know this post is pretty old, but does anyone know if this carbontrix hood is still available??
  14. snowborder714
    12,073
    228
    Joined Oct 15, 2006
    3K  0
    Loading...
  15. cioc
    cioc Proven Member
    190
    33
    Joined Aug 2, 2006
    Sparta, New Jersey
    I just got one from Carbontrix but they changed vendors and it took 6 months to receive.
    3K  0
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
  16. Bud92gsx
    Bud92gsx Proven Member
    7,996
    114
    Joined Jan 16, 2008
    Wisconsin, Wisconsin
    I dont have any data as to Underhoods temps. But theres an old school mod of using a few washers where the hood mounts to the chassis.
    4K  18  14
    1992 Mitsubishi Eclipse GSX
    13.300 @ 102.400 · 1G DSM
    Loading...
  17. snowborder714
    12,073
    228
    Joined Oct 15, 2006
    Terrible idea. Cowl venting doesn't work on our cars.
    3K  0
    Loading...
    Bud92gsx likes this.
  18. Bud92gsx
    7,996
    114
    Joined Jan 16, 2008
    It probably doesnt work. I have no log data to show it doesnt work, I wish I did.
    4K  18  14
    Loading...
    performance likes this.
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
