Holset HX40 Part numbers (wheels, housings ect)
billman
Jan 31, 2008
Munich, Europe
Hi,
i am new in the forum. I have 2 HX40 Holsets but they have the 56mm inducer 8 Blade impeller. I would like to install something bigger. Do you guys maybe have the Holset part numbers for:
6 blade impeller with 60 mm Inducer and the compressor housing to fit this.
7 Blade impeller 60mm inducer and the compressor housing to fit.
Thanks a lot
My old 8-blade HX-40 was 58mm compressor. Look at Htturbo.com for info on the upgrades. Look in turbo tech for all 3 holset threads and read up like I did.
Chris
I i have 3 of them. The two of them have 56-57mm inducer and the third one 55mm. I also read all the thread 1+2 some time ago and 3 yesterday but i dont recall if the information i am searching is in the older threads and to be honest i dont have the patience to go through it again.
to make it more interesting here some pictures. I plan to run it on an Audi RS2 5 Cyl engine with a modifyed K26 housing (it is an old cracked housing machined to accept the holset turbine impeller).
I believe it is about .55 AR. How do you thing would it go on a 2.5 liter engine. Where would the small .55 AR be a restriction?
Here the turbos (i want to modify the one with the damaged housing)
Holset HX40 16 and KKK K26 6 comparison:
I believe the mitsu bolt on housings made by Bullseye for Holset turbo's also feature a .55ar. They don't choking power until you get into the 500+whp range I believe.
Hi,
Thanks a lot
Any infos on these part # s?
Hi, i spoke with brandon and he was very helpful but i wanted the part numbers so i maybe buy them directly over here (Germany) from the Holset dealer. Unfortunately they are not able to search for custom things. So i must give them precise part numbers.
thanks
I have HX35 7blade with k26 turbine housing in 2.2 20vT engine:
It's spool at 2900rpm and I have full boost at 3200rpm. I charge 1.7bar of boost. Car goes to the dyno in next week.
