HKS 272s
notractiongst
165
Jan 27, 2005
baltimore, Maryland
all you guys that are running 272s how much vacuum are you seeing at idle? im seeing like 9 - 11 In HG i think i may have bent a valve or did you guys loose vacuum too when you installed 272s?
my idle is pretty lumpy tonight for osme reason i was getting around 5 HG of vacuum if i bent a valve would that decrease my vacuum at idle?
Using engine analyzer it estimated a 2.0 to pull 13.7 inches of vacuum, and a 2.4 to pull 15.9 inches of vacuum. So you should see a few inches more with a 2.4.
Of course, since you bent a valve, it is no longer seating right, there for lowering the motor's compression with leads to low vacuum.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
