Higher whp in 4th
dsmmike50t
280
Dec 16, 2006
Brampton,
When on the dyno I think you can either go in third or fourth but 3rd gear is recommended. I seem to be getting higher whp readings in fourth gear according to dsmlink it's reading around 399whp and the highest I was able to get on the dyno was 336 on dsmlink which wasn't far from the actual 328 I made. I'm wondering how many of you guys run in 4th,it seems that 4th will give out higher numbers.
link ( pull starts at 514.57secs )
http://files-upload.com/files/605354/run1.dat
The only thing you should get more of in 4th is load and sheared gears. You want to run the closest 1:1 gear ratio you can, which I believe (1.115:1 versus 0.833:1 of 4th). The HP in Link is supposed to just be an estimation, I don't think I've ever had that displayed.
