El Cuervo
- 576
- 27
- Nov 7, 2004
Omaha,
Nebraska
I'm using permatex high temp thread sealant on some fittings for a new oil drain set up and oil pressure sensors and such. The direction on the cover say that it takes 4 hours to settle and 24 hours to fully cure. Well, my problem is that its been a week since I applied some of this sealant and well, the sealant hasn't dried yet. Its still gooey/sticky/fresh. Not as creamy texured as when it comes out of the tube but still fresh enough that I can get it on my finger when I go and touch it to test if it has cured. This is the only thing holding me back from taking the talon off the jacks and testing it. So, what's your experience and such with the permatex high temp sealant when it comes to the curing/drying process and how much time do you actuallu wait.
Thanks.
I accidentaly double posted this threat. If a moderator could delete one I would apreciate it.
Thanks
Thanks.
Thanks
