92PandaTalonTSI
- 97
- 1
- Oct 3, 2011
Bethlehem,
Pennsylvania
Hey guys,
I was having a problem with my tubular manifold to turbo studs. The vibration was backing the nuts out which eventually lead to a huge exhaust leak pre-turbo and a burned up gasket. I just purchased a new beast gasket from extremepsi. Now I just needed to stop the studs from backing out which led me to search for high heat threadlocker. Upon searching, the highest I found at first was 450 degrees. Thats not gonna help!!! Then I came across this product:
http://www.cotronics.com/vo/cotr/pdf/907ts.pdf
I purchased the red one. The temperature range goes from -300* F to 2100* F. Only problem is that its about $40 for a 4oz container. I'll add a review later this month when I install everything back together on my car!
