91-gsx
- 932
- 11
- Mar 31, 2005
San Jose,
California
i was just tuning my car and when i noticed it was knocking at higher rpms, i richened the wot switch on my maft by 5% so the knock went away, but i did the same in the mid switch and that took away the knock too. so it pulled hard up until about 5,500-6,000 rpms and then it would buck a lot and it still wanted to go to redline, but it did it slowly becuase of the bucking and there was no knock logged, am i running to rich(dont think so) or is there something simple like a boost leak? any help is greatly appreciated.
thanks
thanks
) it was putting too much fuel in at higher boost and was dropping a cylinder. Pull your plugs and see how rich you are running after a hard pull and the car is properly timed and cooled. I'd just definitely do what people are saying, check gaps, plugs, wires, and above all, a boost leak test. Good luck
