High Performance Clutch Options
95TalonOwner
1,311
27
Oct 18, 2005
Milwaukee, Wisconsin
I just got my turbo kit in last month and after a month of 9psi, my clutch is starting to slip. What are the aftermarket options for the 2gnt and where can I get them?
Search man search....but I'm a put you on some game......type in southbend clutch in the dsmtuners search engine, or type in spec clutch....whatever you do just remember we run with a modular clutch design so whatever you pick its goign to come with both the clutch and the flywheel which is why they cost more.
A must place to check out is the www.2gnt.com website and just look under the drivetrain forum, this topic has been beating to death, and unless someone has anything new to add to it, I can safely say it hasn't changed all that much.
I agree... do a search. Even here, in the 420A Drivetrain Tech forums you should be able to find your answer.
South Bend consistently impresses 420A owners... the other companies don't.
