high oil pressure and BS ?
bd91talontsi
Jun 20, 2007
Blacksburg, Virginia
ok so I'm fairly new to the dsm world and have a question
I was having trouble with high oil pressure and couldn't find the problem it had me perplexed then I went outside the other day and saw a belt hanging down outta the car!!! upon closer examination it turns out the balance shaft belt had broke, from the research I have done I think that is the cause of my high oil pressure, and I have no clue how long I have been driving around with the belt broken!!
ust want to know if driving with a broken BS belt could have caused any engine damage? or if I can chill and not worry about possible damage being caused to my engine!!!
from what I could find here about it It seems it wouldn't cause any damage just make the engine run a little roughly but still want to be 100% sure, any feedback will be greatly appreciated
thanks
What can I do to lower my oil pressure, it looks like my fresh engine build blew the seals on my turbo and I'm really not in the mood to be pulling the whole thing apart again. Did I miss some integral part of putting the motor together? What kinds of things cause high oil pressure? I don't think there's anything blocking my return line.
When you do the balance shaft removal port the relief valve in the oil filter housing.
I think 80-100 psi at wot is good. Anything over that is to much period.
But by 7k anything under 60psi I think is too low. Imo...
  • Wanted 6 bolt NT water pipe
    • chrisman287
