high idle?, over heating?
wpj92
Mar 14, 2009
Palmer, Massachusetts
my 2g has a high idle to it it runs any where from 1500 to 2000rpms any ideas
car is over heating do not no why
fan works umm only starts over heating 20 mins after car is started and driving.
not low on antifreeze
hole in the catylic converter if that matters ffor the high idling
Have you checked for boost leaks? I recently changed my injectors and my idle was high as well. It turns out that two fo the lower injector seals split in half. I was totally dumbfounded. Also run the check in your IAC.
