2G High Idle. MAFT help
majik2k5
799
18
Jul 13, 2005
Lemoore, California
Ive replaced all gaskets around throttle body, attempted to adjust the translator, and still have a bad idle. And by bad, I mean high. It idles around 2000 rpms. Of the four switches, which ones should be on and which ones should be off? Also, between shifts, the rpms do not drop like they should. They do drop, but very slowly. Any ideas?
Have you check your Fuel trims? Try to adjust the fuel issue first them adjust the mechanical parts.
You need a datalogger and other way to control the Fuel like S-afc.
Read this why.
Make sure you throttle plate is closing completely. Your throttle cable should have a little slack to it and should be making contact with the idle switch(see picture, it is one of an open throttle plate but serves as a reference). -Brodie
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
