help high idle
Fred9981
35
Oct 5, 2003
i just got my engine rebuilt like a month ago and i have the isc go bad on me. the idle was bouncing from 1k rpm to 2k rpm and i installed a new isc and and i justed the idle through the biss screw and it was running good with no idle problems for a week and now the idle goes to 1800 rpms when in park i adjust the biss and its good for a while and them it goes back up. isc is still good i check it already and the biss screws is good to
some one help me
thanks
your biss screw is backing out if you continually can adjust the idle with it. To solve this problem replace the o-ring (#5 i beilieve) and use some vibratite or silicone on the threads to hold it in place.
the codes that the computer gave me are p1500 and p0505
does any one know what the mean
what do this codes mean and how can i trouble shot this
The idle air control has a mafunction in the circuit i.e an open excessive resistance, short to pawer, short to ground or the is just a bad idle air control. the other code is for a generator(altenator) circuit malfuntion.
Andrew
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
