HIgh idle idle surge no boost leak, blocked off fiav, tested 2g isc
corwininadsm
59
Feb 10, 2006
Olympia, Washington
hey i have a high idle and it surged if i plug in my tps
i pressure tesed w/ no leaks
blocked off fiav
2g isc tested fine
idle was higher than with a 1g isc
ideas?
specs are in profile 6bolt swap etc
im tempted to get a blockoff plate and just use the isc screw
i rebuild my throttle body myself with new washers
is it possible that when i rebuild the throttle body that the butterfly valve doesnt make a perfrect seal even tho it bolts up perfectly and looks fine (i cant see any light through the edges.
anyone used the blockoff plate and had any good luck?
lemmie know
ohh and the idle is perfect when cold and slowly comes up as the temp goes up
I used the block off plate that blocks off the fiav and isc. When its cold its a little rough getting to idle till it warms up but if you drive it right away its fine once it warms up, just wait to adjust the biss once its warmed up mine idles smoothly at 850 now :thumb:
thanks mine idles a little rough now at cold but its atleast at 750 and then slowly coms up as the temp increases. i think im gonna try the blockoff plate now
