High idle, but no surge...
Vertigo RT
31
Sep 29, 2012
Palm Harbor, Florida
Hey, guys... got a quick one, I tried a search, and only came up with the BISS solution, or an isc.
Id gear the car idles happily just fine at ~750rpm. When in park/neutral it will sit between 1100-1400rpm. I thought of the BISS screw, but bringing it down to 750 in park using almost kills the car when putting it in gear.
My Talon had an issue with the isc, but it caused idle surge and would idle erraticly at stop lights even in gear, so I tend to believe theyre not the same issue.
Any thoughts?
Well, yea... sat down and had a sandwich...
Oh, right, boost leak test, LOL...
Yes, performed it upon getting the car. All seemed well
Will do. Whats the correct resistance?
I assumed if my ics was bad, my idle would be all over the place.
Can try tapping the ISC. Make sure there is some slack in the TB cable. If that doesnt help momentarily pinch or block off brake booster hose and other vacuum sources while at idle condition and watch for a rpm drop. Good luck!
