High idle after c.o.p install?
blackhawkgsx
250
Mar 6, 2010
Miami, Florida
I have installed the 300m cop set up. i wired it my self using a write up i found here it works and every thing but my idle is at 2000 any idea why any one?
I have 6bolt bottom end in my 2g with 1990 cas
Any ideas any one?????? PLease!:pray: I dont like my 2100rpm idle:notgood:
thanks for your insight how woould i go about doing so? i have searched and came up with nothing also have the manual from advanced but it was accidentally left out in the rain:ohdamn:
every thing was fine before I did the C.o.p set up idle was 750
You just find your throttle cable running behind the IM going to your TB, there are (2) bolts securing it to the manifold. If the bolts are putting tension on that throttle cable it will hold it open, as if you were giving it gas. Check and make sure that cable isn't pulled TIGHT pulling open the throttle plate...
-[RESOLVED]Throttle Cable Stretched
-Gas Pedal Stuck Down
:dsm:
