HID Retro Number 3 (2Ga Headlights)
Some people collect turbos....I collect LED/HID projectors.
Just before Christmas I picked up a set of Corolla LED projectors for steal. They came complete with the whole headlight bucket and drivers.
Bit of JB Weld Steelstik and they were mounted.
Quick test, much better beam pattern and cut off then the X5s. These are an actual main beam and not a fog light, there was a high chance the X5s would have been cosmetic only and that just didn't sit right with me.
The headlight housing had to be trimmed a tiny bit but other then that they fit fine and the rear cover should go on.
Should look pretty sweet when all done.
I picked up some mirrored acrylic to make block off plate out of, they will go around the projector and hide most of the guts.
My mirrored arcylic idea didn't work out as planned, it's a bugger to cut unless you've got all the right tools plus it's rather brittle.
So I made myself a cheap vacuum table out of some MDF and peg board, the frames were made from screen frames.
Bought some polystyrene sheet, put in the frames and into the oven for a couple minutes till it started to sag.
Turn the shop vac on and pressed the sheet over the headlight.
Molds held on to the headlight reflectors nice and tight.
I made a total of 4 pulls and got 2 decent moulds, I'll likely make some more pulls later as once I trimmed them they were not 100% perfect.
Final trim and laid over the projector. I'll use some Goop or JB Weld to secure it to the projector when the time comes.
I modded the Colloras to get more light and a bit of color back, lens is moved around 2 mm forward and has 3 lens spacers installed. 2nd picture is the stock Corolla on the top and modded on bottom. 3rd picture is a comparsion to the TLs (3Five bulb and ballast, color modded with 2 spacers IIRC).
Finally everything laid back into the headlight, Corolla LED covers and headlight bucket have been painted, still need to repaint the headlight shroud. By the end of the weekend I should have everything hard mounted back into the buckets.
