HID Help!
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
Okay so I got the xtune HIDS with the ebay projector housing and I need some install help bad. I was assuming this was plug and play but it might not be.
The things in red I dont understand.
1 2 wires (red and black)
2 What to do with the harness that goes to the OEM headlight
3 What to do with the pigtail coming out of the high beam
I can barely read the schematic you have, and not very much info on this xtune h.i.d; I would call their tech support on the paper work that was enclosed in the box. You may have got the wrong part sent to you, or they may have boxed it wrong. :thumb:
b.t.w this is supposed to be used on the low beam circuit and I see your schematic shows it going on the high beam circuit? Some electrical engineer does not know how to draw a simple schematic correctly. So yes, I see your confusion.
