Hesitation at WOT
fishtank
Jan 25, 2005
regina, SK, Canada
Well heres my problem. When doing a pull in any gear my car hesitates around 5200 rpm. I have no problem building boost or holding it either. But as soon as it gets close to 5200 the car gives a slight buck, but will continue reving up after.
I have just replaced the plugs with new ngk bpr6es have new accel 300k thundersports wires and have also just changed the fuel filter.
car is stock running 11psi of boost
plugs are gapped to .028
temp outside is about -20 celsius
Is there anything else i should be looking at as a cause for this
Just because you can build and hold boost doesn't mean there's no leak, Do a leak test first so you can eliminate it for sure.
Fixed my problem had 1 tiny little boost leak at the injectors... but it ended up being leaking capicitors on the ecu. Which in turn kept reseting the board and shutting off the fuel pump, swapped in a new ECU and everything works awesome. Thanks for the help anyways
Did it just hesitate? Or did it sputter all the time after 5200 rpms. 'cause that's what mine's doin right now.
It would do both, i would still do the leak test first and make sure but check the ecu if your still up in the air and have looked after all the other basic stuff.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
