dpok69
- 0
- Oct 18, 2010
NYC,
New_York
Here is the car a bought a month back with mods done already
Engine mods: 6 bolt block
Acl Bearings
New oem water pump
New timing belt with adjustable cam gears 280 BC Cams .020 bore over
All new seals from top to bottom
Crower springs & Retainers New guides and lifters
ARP head studs
Wiseco pistons
Eagle rods MLS
metal headgasket
Stainless steel Crower valves
Tranny Mods:
New set of synchros
Act 2600 clutch
Findanza flywheel
Short shifter
Quaife LSD
Forced Induction:
PTE 5857 Ball Bearing turbo
PTE 750HP intercooler
PTE 1000cc Fuel injectors
3 inch Stainless Steel Exhaust Tial Blow Off valve Tial 38mm wastegate
Aeromotive Fuel Pressure regulator GM maft setup in blow through configuration MBC
Dsm link 2.5
Tell me what you think.
Acl Bearings
New oem water pump
ARP head studs
Wiseco pistons
Eagle rods MLS
metal headgasket
Tranny Mods:
New set of synchros
Act 2600 clutch
Findanza flywheel
Short shifter
Quaife LSD
Forced Induction:
Dsm link 2.5
