Help
mitsugsx99
45
Jan 22, 2012
zion, Illinois
Why does my car sound like an sti when I drive down the road I push the clutch in it let it get to an idle it stops but comes back WHY
also before it sounds like an sti you can feel the car kinda stumble first
Are you 6 bolt swapped? Any way of logging? That sti sound is called a misfire, and is a physical engine mis. Usually spark related.
The mas is all plugged in just double check and its fairly new and I replaced all the intercooler pipping,clamps, and boots
Yes I recently did a 6 bolt swap took it to Devo 2uning because it had a bad idle surge and other small things I just replaced the plugs and wires what else could cause a mis firer
And Yes I recently did a 6 bolt swap took it to Devo 2uning because it had a bad idle surge and other small things I just replaced the plugs and wires what else could cause a mis firer?
