Help
Nosroxs
150
Apr 16, 2011
St. Louis, Michigan
Hey guys, I got a 96 eagle talon tsi mostly stock i just had it in the shop for a clutch replacement got the car out and it spits and sputters, i cant get it over 2000 rpm's runs like crap stalls if i don't give it gas and cant figure out the problem, any insight on what to check??
If your car was running fine before going into the shop then it has to be something that they did at the shop..
I would take it back and have them fix it. Unless you want to fix it yourself.
Sounds like a boost leak to me.
Sorry i posted guys i did take it back it was a bad power wire grounding out messing with the ecu or something they fixed it and now it runs super good,, no first gear tho :( must be a transmission problem thanks for the reply alan
Sorry i posted guys i did take it back it was a bad power wire grounding out messing with the ecu or something they fixed it and now it runs super good no first gear tho :( must be a transmission problem thanks for the reply alan
did first gear work before the shop?
